Old 10-13-2022, 01:40 AM   #6 (permalink)
freebeard
A quiet evening at Ecomodder, so I took a look at Physics dot Org.
Physicists probe 'astonishing' morphing properties of honeycomb-like material
"The quantum material in question is known by the chemical formula Mn3Si2Te6. But you could also call it "honeycomb" because its manganese and tellurium atoms form a network of interlocking octahedra that look like the cells in a beehive." Sounds like Fuller's Vector Equilibrium. Needs further attention.
Scientists demonstrate that electricity may be obtainable from water with a high salt concentration
This suggests getting electricity from river water flowing into the oceans.
New tool helps researchers investigate clouds, rain and climate change
The tool generates second-order effects from the model, for comparison more directly with the radar data that is gathered. And it's open source.
Watch brain cells in a dish learn to play Pong in real time
800,000 neurons self-asemble in a dish!
Like the Electric Prunes, I had too much to dream (last night). And I haven't even looked at the Nanotechnology tab.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
