Old 10-21-2022, 01:34 PM   #7 (permalink)
aerohead
UV
http://https://www.google.com/search...QxsUjvcJt5gWBM
Does this video just describe UV coating glass with extra steps? It does apply to other materials, which is wildly different, but for glass, it just sounds like a more complicated way to UV coat it.
Seems like it's about what an individual would experience when 'wearing' or 'inside' the technology.
UV flux would still intercept the material, but the amount of infrared radiated to the individual would be mitigated to some degree.
What's seldom mentioned is that, global warming increases evaporation, raises relative humidity, and the heat index, and it's the heat index that's killing people.
And simply lowering the dry-bulb temperature of humid air actually 'INCREASES' the relative humidity, as the air moves closer to 'saturation', making it it even more uncomfortable or deadly.
Only refrigeration can take the moist air below dewpoint, and condense out enough water vapor to bring the enthalpy of the air to within the limits of human comfort.
Any air conditioning contractor can provide a 'psychrometric' chart, used to engineer heating and cooling systems. They're available online as well.
Xist (10-30-2022)
