Old 10-24-2022, 02:46 AM   #1348 (permalink)
cRiPpLe_rOoStEr
Looks like someone built a rotary motor for small aircraft. Rotax had done that along with others that have faded into oblivion. If you can shove one into a bug or porsche then with a bit of thought it would fit into a typical american car with one cylinder facing down where the oil pan now sits.
I guess you're refering to the 3-cylinder Radial Motion engine. It's radial, not rotary. Well, maybe it could fit to the frame of an American car too, as long as there would be not much interference from the 2 lower cylinders to the frame rails.
