Old 10-25-2022, 07:31 AM   #14 (permalink)
Logic
Originally Posted by jakobnev View Post
Why use petrol or diesel tho? For me it only makes sense to do this if you can do it with something that is both cheap and unusable as motor fuel in it's original state.
I just posted a link to a blow torch warming up where one can see the difference between a fuel burning as a liquid and as a gas.
The same trick was used on old tractors that started on petrol, then changed over to paraffin once warmed up.
NB: that these engines had a very low compression ratio, so the octane rating of the fuel was of no consequence...
In today's engines one would have to use Diesel ignition.
ie:
Spray in the fuel at the right time to auto ignite, rather than a spark at the right time.
My point being that:
No; you don't have to use petrol or diesel in the steam reformation process.
Any old oil/s etc should work to some useful degree.
Search:
plastic to fuel pyrolysis
But it does seem that methanol works best at the temperatures attainable from waste exhaust heat.
pgfpro (10-28-2022)
