Old 10-26-2022, 10:27 PM   #1119 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
OK - although I Really wish there was a direct input from my computer, like every other site I use. The 1956 Jensen 541 has a wide oval air intake, with a shutter that rotates like a carburettor choke, along the long axis. It is manually controlled, and recommended for quick warm-ups, but probably gave better performance if partly closed at speed. Unfortunately, there were no diffusers and ducting to reduce turbulence, as needed for an ideal variable intake.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Piwoslaw (10-26-2022)
