'Think Flight' V2 noodling
I ran an energy balance for all the Subaru configurations.
The conditions were:
65-mph ( 95.333 feet/second )
estimated Af= 23.8153 sq-ft OEM, estimated 24.4394 sq-ft with airdam
rho = approx. 0.0023256823
Cd 0.29 ( CarsDirect.com )
tires- 205mm width
REGULAR Unleaded, reformulated gasoline @ 111,836-Btu/gallon
6.138-pounds/ gallon
CVT transmission of 87.71% mechanical efficiency
40% thermal efficiency for engine
2546 Btu/ brake-horsepower
2.2% engine accessory losses
Rolling resistance power absorption is carried as a constant
Brake Specific Fuel Consumption ( BSFC) is carried as a constant
configuration-1: Cd 0.29, CdA= 6.9064 sq-ft, 35.644-mpg
configuration-2: Cd 0.214, CdA= 5.0981 sq-ft, 40.528-mpg
configuration-3: Cd 0.2671, CdA= 6.5289 sq-ft, 36.5637-mpg
configuration-4: Cd 0.1764, CdA= 4.3114 sq-ft, 43.0971-mpg
configuration-5: Cd 0.2291, CdA= 5.5467 sq-ft, 39.4562-mpg
configuration-'6'* Cd 0.1721, CdA= 4.2060 sq-ft, 46.5376-mpg
'6' represents a 17.3% radiator blockage to compensate for a now, 'oversized' radiator area.
The 'source' flow for the underbody and diffuser originates at approx. 16.11-inches above ground level before displacement. The separation edge for the slanted diffuser should not be any higher than 16.11-inches, as, at this elevation, the displacement kinetic energy nulls, and constitutes the 'reversal point.'
Additional 'fruit' which lay outside the scope of the Impreza project, if added, could easily bring the Subaru into Cd 0.145 range
Reason: add data
