Old 11-02-2022, 02:04 AM   #15 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Logic View Post
Hmmm... that woke the 'conspiracy theorist' in me...
There are many conspiracy theories about Jean Pierre Chambrin roaming around. Some say the reactors which "disappeared" in Porto Alegre went to different places, one remaining in Rio Grande do Sul (I just don't remember if Alegrete or Bagé) while the other was reportedly in Arizona or Utah.
Some sort of direct gas into cylinder injection system will be required and I doubt current systems will work with, or can be modded to work with, a gas.
Maybe looking at the system fitted to some CNG-capable engines such as the Volkswagen TGI range for inspiration, even though the higher temperature required to turn a liquid fuel to the vapour phase may be an issue.
