Old 11-07-2022, 06:58 PM   #24 (permalink)
Xist
This guy says that when you connect solid wire to stranded you extend the stranded wire further than the solid and you always twist wires together twice after you splice them:
[so, not how the amateur does it there]
Also, apparently beginners twist wires together and wrap them with electrical tape, without using twist caps, butt joints, wagos, or solder!
