Old 11-11-2022, 07:22 PM   #17 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Phase View Post
so there should be some type of aero benefit for blocking off the lower splitter grill even though it's so small?
and ill only be doing this grill block in winter weather here and will take it off in late spring. worst case scenario, is that the upper shutters should actively open if things get too hot, even in winter, right? as long as everything is functioning properly, i should be set?
I think there could be aerodynamic detriment to blocking it off. A high static pressure being relieved can reduce drag if done right.
Also a 100% block is asking for trouble at some point. Engine coolant temps are used for controlling the cooling fans but other systems like electronics are stressed by higher under hood temps.
