Old 11-14-2022, 11:34 AM   #15 (permalink)
aerohead
' Think Flight V1 & V2'
Originally Posted by Cd View Post
Whoa ! I am just now seeing this. I just posted a similar question Aerohead. Sorry 'bout that
Since you bring up ThinkFlight's design, you might notice that it falls out of the Template curve. ( Have a look at his second video )
This got my attention, because despite having too steep a curve at the rear, the design had great attached flow all the way to the tip of the tail, and even along the centerline.
1) The V1 tail follows the 1935 FKFS, 5-configuration, 'Kamm' test model, and W,A. Mair boat-tail contour. It's upper slope, for it's 'length, never exceeds 19-degrees, while the diffuser goes off reservation, @ 20.5-degrees ( impossible for flow attachment).
I estimate Cd 0.214 for the 40.528-mpg performance.
2) The V2 tail, with airdam & rocker panel extensions, conforms to W. A. Mair's initial contour, and evolves into the 1981 Cd 0.14, VW Flow-Body( long-tail ) contour, 'peaking' @ Buchheim et al.'s 23-degrees at top ( classical limit for flow attachment ), and the diffuser has been relaxed down to 5-degrees.
This #4-configuration is estimated at Cd 0.1764, to explain the 43.097-mpg ( a 20.99% mpg increase).
Cd (11-14-2022)
