Old 11-15-2022, 11:32 AM   #60 (permalink)
Piotrsko
Silicone seal is water vapor cured. Below 32 degrees there isn't a lot of local humidity to begin the cure. Warm it up above ambient and it will be fine but a slower cure. I myself use a 100 watt incandescent heat bulb typically out of a bathroom.
