Old 11-16-2022, 10:33 PM   #25 (permalink)
Circlotron
Maybe an idea to put to rest whether a WAI reduces pumping losses - Set the engine idling with CAI and if the IAC uses a stepper motor, note how many clicks open it is. Then switch to WAI (preferably without switching the motor off) and see if the IAC opens up a little to maintain the same idle speed. Or for that matter, see if the manifold vacuum drops a little after the change.
