Old 10-16-2008, 11:24 PM   #14 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
A few thoughts: the prop on the RC car is in relatively "clean" air,whereas behind the van/suv,it would be in the lee of the vehicle,with only the turbulent wake as a source of air.That means the prop would have to induce air from behind itself,forward around the outside of the disc area.Then the air would be blasted rearward through the prop,setting up a circulation of sorts(like a helicopter in ground-effect,only sideways)making it difficult to induce the air forward again,to re-circulate through the prop.Unlike a suction slot,the prop would have no boundary layer effect,and a dubious amount of thrust if any,only stalled,in a region of recirculating air within the wake.--------------------------------- Also,to get 10-hp of thrust would require about 12.5-Bhp at the shaft (very inefficient).-------------------------------- Finally,as others have touched on,the safety ramifications,should some unfortunate motorist or cyclist rearend the prop,is too grim to even contemplate.
Yeah, forget the prop. I've seen too many RC airplane accidents to think
a large prop is anywhere near safe.
BUT, a ducted fan might be usable. A good one might develop some pretty good thrust. EDFs have the advantage of shorter blades (impellers), thus lower RPM & tip speeds. Big props & big HP get tips speeds up near mach1.. Not good.
Now that I have the coro spoiler and wake boards installed, I did some yarn testing back there.
There is almost zero turbulence on top of the spare tire and across the rear glass..
Where did it go??
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
