Old 11-20-2022, 05:02 PM   #157 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I would say your testing conditions have a real world error of a handful of percent. So it would really be impossible to test if that stuff really worked with such a low percent change. Maybe if your car got 50.0mpg evey month of the year it would be more verifiable.
Yup check your caliper slide pins, slide clips, clean and lube if necessary, check the boots on the halfshafts and make sure they aren't leaking and creating a dry or dirty noisy axle, pull on the hubs up and down and check for play.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
