Old 11-23-2022, 10:24 AM   #3 (permalink)
Piotrsko
Find the control signal for the abs system and use a mosfet to sample when it activates. Or a Throttle pot on the brake pedal set such that more pedal gives you more or less signal/voltage.
However there will be a lag time in milliseconds between activation and appropriate movement of any surface so use in a panic stop may require some janking about
Cd (07-01-2023)
