Old 11-26-2022, 11:58 PM   #53 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Talos Woten View Post
By the way, filling in the hood with foam would also 100% definitely work and add more insulation. But it would also 100% change the acoustics, and most hood gaps are tuned to counter the engine frequencies. I don't know whether the added sound-proofing would be sufficient to compensate for the loss of the dispersion cavities.
AFAIK it had to do more with pedestrian safety than sound-deadening, with the engine sitting lower and some impact being absorbed before the hood is dented enough for the pedestrian to hit the engine. BTW I remember the 1st-gen Ford Edge had engine covers made out of foam instead of hard plastic, which seems to perform quite well for both heat retention and soundproofing the valvecover.
