Old 11-27-2022, 10:41 AM   #39 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Problem with ground clearance is you're always limited by wheel size. Once a control arm or pumpkin is dragging, that's about it. There's basically no getting around to ground clearance being limited to half the height of the tire, and a little less. Every inch added results in half the ground clearance gained.
Fluffy stuff can be pushed a bit. My buddy Craig with his custom made "Craig Chains" where he replaces the cross links with large diameter chain links can push quite a bit, but it piles up quickly and there's a limit, and clearing that limit takes a lot of effort.
Machines made to handle the snow float it, not penetrate it.
At this point in my life, I think I'm more about low ride height for efficiency and handling, and the right machine for when the snow accumulates. I don't yet have the right machine for accumulated snow.
Getting stuck in deep snow in my "low ridding" sedans and hatchbacks only happens about once every 5 years (even with snow tires and chains on), which is why I carry around a shovel in the trunk. There are a few dirt roads it would be nice to not have to scrape bottom every now and then in the summer (even with carefully trying to avoid stuff). A couple inches more might be all that's needed. But then again it's not worth it to me to go get a CUV/SUV/pickup or install adjustable height suspention on the car. Only if someone would trade their Suzuki Samari for my Prius would I be at all interested in the idea.
