Old 11-27-2022, 01:49 PM   #54 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Phase View Post
Pic of the Ioniq engine bay. So it would be safe to lay something over this? What about the belt?
I'm actually surprised an Ioniq has a belt drive. My favorite part about owning the prius is it doesn't have a belt drive. They simplified a lot so less complex.
Anyways... Yup the main point here is heat rises so the majority of the heat retention is putting the insulation over the head. Just throw a sheet on there and try not to insulate your inverter.
The most really that happens is its a pita because if you touch the **** you will be nice and cozy... i mean itchy...
Worse case scenario the belt drive rips a piece off and some of your insulation is gone. It will just pull it off like cotton candy as the stuff is hardly together lol
Take the hood liner out too, it'll give the insulation more fluff room.
Take that massive engine cover off too if you can. should improve performance of the insulation.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
