Old 11-28-2022, 08:33 AM   #56 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Phase View Post
thats where the air filter is. not engine cover
i keep seeing things about ceramic insulation foam sheets. they cost more than the basic r13 fiberglass. would they perform better or is it a different type of insulation?
also how can you even go about getting smaller bits of insulation? cheapest i found was 30 bucks at home depot and 32 feet long. i just need 8 square feet for mine give or take
home depot and lowes locally will be your cheapest and a roll is $20 at the cheapest i bet. The ceramic kiln insulation is good as well. Higher R value per inch. But probably 10x the cost so instead of $5 it'll be $50 for a similar size. But 2" ceramic will be like R20 right since its so thin but R-10 per inch. Its also not to be breathed in like fiberglass, asbestos, etc... We aren't building a house out of it though so its pretty easy to not breath it in.
Yikes well that sucks. Thats the biggest engine cover and airbox ive ever seen. My insulation is sitting right against my metal valve cover.
Just drive by a neighborhood being built. 90% chance a guy will get you a piece if you ask nicely. They have a lot of scrap when they build houses.
Get fluffy insulation though not foam board. Foam board would suck in this application.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
