https://www.homedepot.com/p/UniTherm...50in/309949108
The factory just uses yellow fiberglass insulation on the fire wall with a good cover over it. The ceramic stuff is fire proof and has a higher insulation value. You can throw it in a fire to test it before you use it if you are nervous.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
