Old 12-05-2022, 10:58 AM   #27 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
Sequoia - '04 Toyota Sequoia Limited
90 day: 17.51 mpg (US)
I'm blown away you can get humidity above normal and need to use a humidifier in the winter. The acceptable range for me is around 35-55%. House typically sits around 30% even. Besides being hot and/or muggy above, I feel like im gonna die in the winter from lack of humidity.
Speaking of those electric heating elements. I just replaced the sacrifical rod on my water heater of 18 years. It was half way broken off and 3/4 of the total rod was gone! You could see the inner anode wire in most spots.
I assume the broken off piece will be in the water heater until it dies but no big deal lol.
My natural gas unit seems to be doing good. I endoscoped it and it was pretty clean, had a bit of muck on the inside walls so yum. A bit if sediment and rod flakes at the bottom but maybe a couple mm's. Went ahead and flushed it well, did a soak with vinegar, wire brushed all the threads and connections, and ordered a new 0.9" thick magnesium rod like the original. Trim to fit for $33 and i will have a full 40" rod of connection and not like 1/3 thickness of 23" with galvanic corrosion insulating the threaded connections every where. Maybe it will go 18 more years. NG water heaters seem to be pretty simple and repairable.
I also made a NASA grade R-19 water heater blanket and hat for it. Its almost 3 feet round now lol. I wonder if my extreme case of insulation will help much. I think the water heater bare is r-16. My insulation at actual fluff is around R17-R18. So possibly R33ish total now.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
redpoint5 (12-05-2022)
