Old 12-05-2022, 11:14 PM   #1 (permalink)
leoblack9
tinker
Finally upgraded to 155/80/13s after several years of reading and lurking here
After an unfortunate tire blowout with my old 155/65/14 tires I finally had a chance to apply what I've learned over the years from this forum.
Autopsy report: Huge pothole + 5 year old tire (tons of microcracks in the sidewall). The pictures speaks for itself.
Inevitable event here in Philippines where roads are crap.
I already bought a 13x4.5 steel rim a year ago in anticipation for this upgrade. Tire selection is very limited. Other tire options were GT Radial Champiro Ecos and CST Marquis MR61. I opted for Thunderer since its the freshest tire I could find (DOT 2522) and I didn't have the option of waiting.
Fitted with Thunderer R202 city tires. Made in Thailand.
Installing the new tires. It raised the ground clearance an inch or so.
I picked this style hubcap because its the closest thing to a flat surface that's available in the market. The 90s rounded style also fits the suzuki alto's curves/edges.
Tread pattern
Suspension geometry should still be stock. Its absolutely perplexing why India gets the 155/80/13s as stock with these vehicles while the rest of the world gets the ****tier 155/65/14s. Still same tire width, offset (+45). New tires look absolutely chunky on my car its cute to look at.
Post-upgrade thoughts:
  • Speedometer is now dead accurate to my phone's GPS speedo
  • The ride is supple! I thought i was riding a pushcart with my old tires.
  • Acceleration took a hit. Engine revs happier more with older smaller tires. I was expecting the lesser unsprung weight would offset this.
  • Fuel economy took a hit (as expected). 1 tankful (35L) on old tires: 440km, new tires: 410km
  • New tires are of softer compound. Old Acceleras have 400AA treadwear, New Thunderers have 300AB. I expect fuel economy goes up as rolling resistance goes down with wear.
  • Tires produce a characteristic hum above 60~80km/h. I guess these tires are probably made for low speed city driving. Driving in the wet the tires feel planted. Braking is decent.
~When you're under there, don't half-ass it. Full-ass it all the way~
The Following 8 Users Say Thank You to leoblack9 For This Useful Post:
Caddylackn (12-10-2022), Ecky (12-06-2022), freebeard (12-06-2022), Gasoline Fumes (12-06-2022), Joggernot (12-06-2022), Nathan jones (12-07-2022), oil pan 4 (12-06-2022), Piwoslaw (12-06-2022)
