Old 12-10-2022, 02:18 AM   #13 (permalink)
cRiPpLe_rOoStEr
Even though heat may be required, and the air-cycling system can provide it quite easily from the engine compressors, the same operating principle can be also used for cooling.
I'm given to understand that, they use air as the working fluid because there's available surplus power from the compressor section of the jet-turbines, and if the system were to somehow spring a leak, only 'air' would contaminate the passenger cabin and cockpit.
Some refrigerants are both flammable, explosive, and toxic, especially in confined spaces, like an aircraft.
Not to mention it also supplies the pressurization system.
aerohead (12-12-2022)
