Old 12-11-2022, 03:03 PM   #9 (permalink)
oil pan 4
This one holds and is supposed to have 6.5 gallons of hydraulic oil. I bet it has at least 5 gallons.
Might be low, it only had about 8 out of 21 ounces of oil in the crank case.
I cleaned and packed the wheel bearings. Each bearing had a few CCs of corrosion preventing goop on them definitely going to fail going down the road. Put at least an ounce of grease in each hub.
If the spindles are the same I could definitely put some real trailer tires on there.
