First mod will likely be temperature and pressure gauges on the hydraulic return. The return is easy access to the hottest fluid that's at low pressure. And I'll add a pressure gauge that way when the pressure doesn't change or doesn't change very much as the fluid warms I'll know the filter is clogged and needs to be changed.
