Old 12-15-2022, 11:10 AM   #588 (permalink)
aerohead
pressure
Originally Posted by Phase View Post
Snow melted. Here’s how the dirt deposited. Wonder what this says about pressure too in the rear.
Closely-spaced streamlines mean high-velocity, low pressure.
Widely-spaced streamlines mean low-velocity, high pressure.
The base pressure is determined by the pressure at the separation line.
The only way to 'raise' the pressure is by elongating the body along a streamlined path, which produces the pressure recovery as the streamlines decelerate, trading velocity for static pressure.
( if you've seen the 'blue' wind tunnel smoke-flow image of the VW XL1, you'll see how the streamlines are 'wide' at the very back of the car. This is why it's Cd 0.189 ).
Same for M-B IAA.
M-B EQXX.
It's also why the car doesn't have rear lift and doesn't have a rear spoiler, and is stable at 112-mph.
Nathan jones (12-15-2022)
