Old 12-27-2022, 10:43 PM   #21 (permalink)
freebeard
IIRC the drill press was where I was headed when the mechanic said he could fix it or at least remove the lock cylinder.
The new switch was [apparently] soldered directly to the cable, whereas the 1990 model has push-on connectors.
But it's raining so I don't want to go outside and check.
