Old 01-03-2023, 11:00 AM   #627 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
The Mustang's separation line, without spoiler, is at the AST-III elevation.
Your Ioniq, without spoiler is not.
If you extend the top rear, you need to begin at the tearing edge of the OEM spoiler. It's at the AST-III elevation.
The extension should fall away at a 16-degree downslope.
The sides are likely beginning their camber at the rear axle centerline. That curvature should not exceed what the roofline has.
The diffuser angle will depend on 'where' you begin it's upsweep.
You may have the data for the SAAB 9-3 diffuser research. I recommend comparing that to J. Potthoff's, 1982, UNICAR diffuser research.
It would be easy to make a costly mistake.
How would a boat tail look on my Ioniq then? Can you make a sketch? What should I do about the spoiler? And flow is attached to the rear glass. Hence no need for a rear wiper like a Prius.
The Following User Says Thank You to Phase For This Useful Post:
aerohead (01-03-2023)
