Old 01-04-2023, 10:47 AM   #14 (permalink)
oil pan 4
I was about to so that. Then I got the local Kohler guy to backorder me some jets. I got impatient and ordered those 62s.
The problem with redrilling those holes is I'm needing something smaller than 0.65mm or 0.026''.
But it should be good or at least better with 0.62mm or bettween about 0.024'' and 0.025'', but closer to 0.025''.
I'm thinking about 1 thousandth less hole should reduce fuel consumption around 10 to 12% and get the air fuel ratio pretty close to perfect.
