Old 01-05-2023, 09:49 PM   #18 (permalink)
oil pan 4
I removed the spark arrestor screen which won't be needed once it's running correctly and the exhaust deflector. That with the CAI seems to have leaned it out to only be a bit rich.
The factory WAI, restrictive exhaust had soot collecting around the exhaust.
Oh and when being towed the fuel bowl will tilt and flood the engine with fuel. As if it needs more fuel. The fix for that is when turning off the log splitter I just hit the fuel line shutoff and allow the engine to burn off the fuel in the carb.
