Originally Posted by Piotrsko
The expensive quality installers use dampers in the ducts, the cheapo guys dont. Figure they shave $100 parts and couple hours labor not putting dampers in. People aren't smart enough to know or care. There are aftermarket balloon style remote controlled ones if you insist
Huge fan in the airhandler, only ran full bore once on a hot day rapid cool. Blew the insulated drapes open. Most times you need a tell tale to see the interior fan on, cant hear it run.
Oddly, sometimes it is pushing relatively cool air heating the house
Yep. See it a lot. Well if you don't see main dampers you will need to add some either way new system or not. Track your legs and get a feel where they go and spend $200 bucks on some dampers and add them in one weekend.
Realistically if the upper house is one run you just need one damper
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
