Old 01-10-2023, 03:42 AM   #41 (permalink)
Nathan jones
Ecomodding Apprentice
Originally Posted by S Keith View Post
This is not viable. The PP/PPE modules are so chemically resistant, there is nothing one can use to reliably seal the hole. Screws don't work either. While initial results can be impressive, the modules will slowly lose electrolyte and fail.
I think it could work with less electrolyte and polyolefin primer but with new modules available at great prices and the labour involved I would go with that. It was just an idea as a last resort
P.S. I tried to cheat at getting Tech Stream, but never got it to work. I also didn't see the point in renting it for so much money every year. I miss the days when all you needed was a voltmeter and vacuum gauge.
I bought this
https://www.ebay.co.uk/itm/354015577366
The one I bought was an older version but it works. The one you have try running it in 32 or 64 bit. Also the version it's not supposed to be so try the 32 on a 64 etc. You don't always need the autokent loader
