Thread: Alternator Mods
Old 10-18-2008, 12:02 AM   #23 (permalink)
thefirebuilds
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
Originally Posted by gascort View Post
Like others have said, reducing accessories reduces the magnetic field and thus resistance within the alternator, raising FE. My friend had a HUGE (like 2000W) stereo in his car; when he turned his amp on, it was like a "slowness switch".
FYI - a car's electrical system (necessary stuff like ecm, ignition, sensors) is typically somewhere around 300-400W without lights, radio, etc. Newer cars are more than older cars I'm sure.
Noone's mentioned using a deep cycle battery and a plug-in charger. This is what I'm planning on doing; running a kill switch on my car and when I'm commuting 15 miles to and from work, running on straight battery when I can. The alternator sees no extra duty and the deep-cycle battery is made to be discharged and recharged with minimal sulfation. Electrical power is more efficiently produced in a power plant than in your car, and with current prices, it's way cheaper too!
Agreed. I am on time-of-use so night time charging via a timer switch will be dirt cheap. I have a solar panel to integrate into my trunk that will keep the battery topped off during the day (15w). Should mitigate any issues in most commuting situations.
I plan on leaving the alternator installed so I can belt it up if need-be, but how do i go about finding a belt the appropriate length for just my water pump and main crank pulley? The tensioner on most cars is integral to the alternator bracket instead of the water pump, so i need a way to tension the belt properly. ideas?
