Old 01-11-2023, 09:21 AM   #43 (permalink)
Nathan jones
Ecomodding Apprentice
Try contacting the seller and running as administrator/32 bit. There's also usually a separate loader you might need but in my case it works without. If you fix a toyota group car you need it!!
For the thread guy, your car is fine, just low soc from a low charge drive cycle. The battery memory is always in the low stage. Just go easy on it
The Following 2 Users Say Thank You to Nathan jones For This Useful Post:
broski499 (01-18-2023), Isaac Zachary (01-11-2023)
