Old 01-11-2023, 06:05 PM   #113 (permalink)
freebeard
I suspect there are some processes where a little artificial G would help,
Centripetal/centrifugal sorting to the rescue. Tell some AI chatbot to merge a space program and an acorn.
en.wikipedia.org/wiki/Stoke_Space are showing a solution for a reuseable upper stage capsule that uses a cryogenic fuel tank for a heat shield and an aerospike to land on. No grid fines, just a ring of thirty rockets.
The company operates a rocket test facility on a 2.3-acre spread near Moses Lake [WA]’s airport.[5] Their reusable second-stage design eliminates the brittle ceramic tiles that have required detailed inspections and lengthy refurbishments on other space vehicles.[6]
They have as much startup capital as SpaceX started with. One single, tested motor used redundantly on both first and second stages.
Edit: Here's this...
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
