Originally Posted by Xist
Interesting.
What would you do with an uneven floor?
The subfloor needs be flat within 3/16 of an inch to do a floating or glued down floor. To fix a wooden subfloor that is too wavy you can rent a big orbital sander to sand down the high spots and smooth it out or you can use a leveling epoxy to fill the low spots.
