Old 01-13-2023, 09:46 AM   #12 (permalink)
liquidshadowfox
Originally Posted by Gasoline Fumes View Post
The Advanced Edition has 20" wheels instead of your 21" wheels and has a bit more range. I'm not sure if that's the only reason, but it probably helps.
The Performance edition also has larger 2nd motors (quite heavy) and some additional hardware that adds a bit of weight but yea I thought the same when I first saw the tire size difference.
The Following User Says Thank You to liquidshadowfox For This Useful Post:
Gasoline Fumes (01-13-2023)
