I had mentioned the setup on the array earlier and was just gonna disconnect it via a cigg plug for starting. Im retired and probably drive once every 2 wks and its usually 20 miles round trip.
I could find the answer online but since im here, your almost here ill ask you.
I was gonna connect the array to the main batt... o a new deep cycle is on the way from wallmart as i type. I have some left over #10 wire from running current to the barn. what the consensus on running 2 #10 wires to conncet the array to the main batt. now that i think about it i could take one wire and connect to each terminal and that would id have three wires although it may be risky that one is unshielded or covered. But again, back to usage im probably not gonna drive over 200 miles THIS YEAR.
again, thanks for the input it is very welcome.... porgie
