Old 01-14-2023, 03:49 PM   #62 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Winco was pushing pork shoulder portions for $1.48 lb in Reno yesterday, a whole brisket for 2.48 but I don't need 20+ lbs even portioned and frozen.
I Don't see the advantage of sous vide over crockpot on pot roast or at least on my induction stove. Could be different for filet, haven't tried that.
they are really all sous vide in my book if you are cooking low in water for long periods of time. But most machines will do a minimum temp of 170 (besides a crockpot) and that can be too high for a lot of cuts of meat.
Typically the sous vide machines will do a steak at like 130 degrees and itll will be a perfect medium rare. You just take it off and slap it on a grill to crust it up, or blow torch it.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
