Old 01-16-2023, 04:37 PM   #7 (permalink)
aerohead
tufts / intersect
T'would be a good test case for tuft testing. Do tufts at the leading edge of the bucket stand up in the air?
What happens when two incompressable flows intersect?
* If there is the minimum required radius surrounding the bucket ( top and side ), the air (tuft ) will be slammed against the surface, and pinned there by the attacking flow.
* The outcome of intersecting flows depend completely on the topography of their adjacent surface, local velocity, density, pressure, direction; upstream, downstream, above, below, axially in the boundary layer, and beyond, into the nearest local streamline. It's extremely conditional.
Joggernot (01-17-2023)
