Originally Posted by porgies
Heres what ive done, please tell me what you think. the extra battery is behind the driver seat. i grounded it via the seat frame and run a 4 conductor #12 wire to the main battery in the engine compt. I did find an old switch from one of those power pacts that i can shut off the second battery at iny time, i hve and will not use the cig plug for charging but the circuit that i have used for years, the only difference is now the array is charging two batteries instead of one, thx for your time, porgie
Sounds good to me. I'd just shut off the second battery during starting as 4 x 12gauge wires may be good enough for everything except starting currents.
Also, just in case you didn't know this, although you probably do, use the same amount of wires to the ground. (I knew a guy that would run thin wires to ground and negative and fat wires to possitive thinking that power only ran through the possitive wires.)
