Thank you all. It's not only a financial consideration, more just "downsizing" - I will still have access to 1 ton or larger work trucks if needed, and the smaller work runabout trucks will be cheaper to run & keep on the road going forward, overall.
About 3/4 the usage will be short trips 1-4miles barely enough to warm up, and the remaining longer freeway avg~ 40-120 miles
The frontrunners in this category of older crew cab so far; (thinking I'll probably end up giving up 4x4 in favor of a more common 2wd 5spd 4cyl - otherwise I'd be looking forever for a unicorn, or doing a transmission/engine swap)
-Nissan frontier (2wd) 5spd 4cyl from around 1999+ and the
-GM Colorado/Canyon ~2005+ 5spd 4cyl (4x4 or 2wd)
From what I can find so far, curb weight starts very roughly around 36xx for the lightest configuration listed on both
I like toyota as much as anybody but hard to justify the inflated buy in cost for older tacomas, plus just don't want one of their 6cyl , unimpressed (mpg & reliability) with a 6cyl ex cab toyota in the past
