Old 01-19-2023, 05:57 AM   #20 (permalink)
porgies
porgies's Avatar
Thanks for all the input and the system is up and working, the one mod i do want to add is fuse the second battery, ive found a 50 amp fuse that looks like it was one of those teenager high performance stereo speaker system. The fuse holder is approx 4 mm dia wire so that should be 7 awg ( right?)
So now im wanting to hook this up to my bat to bat + link that is 4x #12 wire. Is that fuse too large for the 4x12 wire and if not it should be as close to the main battery ??? right.
Thanks again for all the hints, helps, comments, and stories....porgie
