Old 01-29-2023, 11:11 AM   #5 (permalink)
porgies
porgies's Avatar
as far as i can tell the hybrid mode only changes the "unit on" when the auto stop is in play. when my sc 2 quits you cant giggle the connection to get it to restart it requires a disconnect and a reconnect and it starts up. I still cant remove the 4 stored codes or even read what they are. it wont cancel the cel lite either although disconnecting the battery will turn the lite off for a short time.
another thing i recently discovered and it was relevant to my other post about my dodge C\V the sc voltage must be the alt volts and not the battery volts. on a recent run i was showing 12.1 v and when i got back to the garage i had 12.9 measured at the battery.
also it was a sunny day and my 80 wt solar aray was online...
