Old 02-01-2023, 10:13 AM   #53 (permalink)
Piotrsko
As long as one end of the drain tube stays attached to the zerk and the other remains submerged or you don't run out of fluid in the master, you can bleed brakes by yourself. I do it all the time. You're removing air from the fluid and replacing the old fluid with new.
