So why do you think there are no cheap basic cars being sold new?
I think a better world is possible. Following on from the WWII Jeep, the VW dune buggies and Arcimoto just takes a little deep-in-one-corner-of-the-box thinking.
Open wheels? Open cockpit? Steel tube roll cage? Wood dash with stab-you-in-the-eye toggle switches? Grille teeth like a 1948 Buick? Check, check, check, check and double-check.
https://kilow.com/
One of
12 AMAZING INVENTIONS YOU SHOULD SEE
An Inexpensive Little EV For Rural Use
While it might have more limited use in the USA, you won’t be paying a fortune for this. Providing you do get a lot of use out of it, you could pick up the La Bagnole for just Euros 9,990 or $9,800. So, it probably isn’t going to break the bank by any means. What’s more, you can drive around in it knowing you are in quite a cute and wonderful little vehicle. Plus, it's one that seems to be quite practical as well, something micro cars can sometimes struggle to be.
www.hotcars.com/kilow-la-bagnole-jeep-micro-ev/
If those grille teeth are coper tubing heat pipes for cooling the electrics, then --- I want this pretty bad.
