Old 02-14-2023, 06:35 PM   #24 (permalink)
mort
EcoModding Lurcher
mort's Avatar
From the description, I don't see any mention of capacity measure. I'm not sure how one would extrapolate capacity from an internal impedance measurement. I could be wrong, but I only know to measure the drain on a battery to determine the remaining capacity.
From the blurb:
It measures the actual cold cranking amps(CCA) ,capability of the battery,the State of Health(SOC),the State of Charge(SOH)
It does compute the CCA from the internal resistance. The formula used is
CCA = 3051.85 / R where R is in μΩ. Which you can do in your head.
This meter can measure the internal resistance of the battery, which you can't do with just an ohm-meter. I assume your resistive CCA meter is a smokin' hot load.
If the battery has a stated CCA you enter that and it tells you % of capacity. Which you can do in your head too.
-m
The Following User Says Thank You to mort For This Useful Post:
hayden55 (03-09-2023)
