Old 02-22-2023, 06:04 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by Phase View Post
Wouldn’t a sharper inward angle with a hard separation edge also just help push my air into the wake? Wouldn’t the ducted air going into the back of the way still have to detach from the backside of the bumper and still create that suction cup effect or lift?
Not sure I understand.
In the example illustration above, if that duct was plugged up, all of the airflow would follow the side ot the Kammback, and exit at the edge, spilling into the wake just like the design with the duct.
The only difference is the amount of air that would be turbulent.
The illustration was just a doodle. The angles are all off, and the air would most likely not remain attached on the edge just before the 'duct'.
The idea is an attempt to get this same effect :
ID:	33475   Click image for larger version
The Following User Says Thank You to Cd For This Useful Post:
freebeard (02-22-2023)
