Old 02-27-2023, 09:57 PM   #38 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
If anybody is wondering you can test for ethanol you don't have to guess. You just get a graduated cylinder with clear markings basically and dump a bit of water on the gas. The ethanol will separate out and join the water at the bottom and you can do the math and see the percent. We get E10 year round here.
The above is why old boats ran E0. Sometimes since the ethanol boost would fall out with the water in the gas tank issue and the motors wouldn't have enough octane left in the gas to run without pinging. The new ones can pretty much run on piss though they are pretty good at pulling timing.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
freebeard (02-27-2023)
