Old 02-27-2023, 11:03 PM   #66 (permalink)
S Keith
Originally Posted by S Keith View Post
I see a LOT of Gen2 ABS actuator failures here in Phoenix. Most that I touch have the initial symptoms of failure varying from 90-250K miles with typical around 140-160K.
I would not regard Phoenix as a humid climate.
The ABS actuators coupled with the poor brake fluid change interval/practices are a $hitty combo.
Argh... wife's 08 with 125K recently started showing the initial symptoms of ABS actuator failure.
Originally Posted by hayden55 View Post
not bad! install takes like an hour and a half so hopefully not too high. But you never know the dealership has a high cost to run.
Most dealers go by the 6 hours book-time + other arbitrary fees. Pretty hard to get a dealer to get you out for less than $2800... and they're making $1400 profit on < 2 hours labor.
